TnTtravelers's avatar
TnTtravelers
Heartland Big Horn Fifth Wheel Trailers
Hello, I'm hoping to find information on Big Horn Fifth Wheel Trailers. DW and I are planning our retirement and were looking for a more full time type of a trailer to go exploring this great nation. We were looking at Montanas and they seem to be full time units, with the 4 season labeling. I was wondering if the Big Horn fifth wheel trailers are considered full time and how they compare to Montana, quality-wise etc... Thank you!
  • 94-D2 wrote:
    I would steer more to the grand design models. Higher price point but better quality I think.
    Grand Design is pumping out slapped together garbage every bit as much as anyone else. If you buy something built while this current situation is in effect, where dealers lots are mostly empty and they can not get units fast enough, you're chances of being handed a POS are exponentially higher no matter the brand. None of these manufacturers care about QC or QA, only the bottom line and they're backed up by their trade organization the RVIA whose main job is to lobby against any lemon law type legislation that is proposed by anyone.
  • It matters where you plan on wintering and how handy you are at rigging a fifth wheel up for winter use. Without taking proper precautions water will freeze no mater what kind of RV you have. Some campgrounds have heated water spigots and all you have to do is heat and insulate your end of the hose and run a heater behind the wall in the front compartment to keep the lines from freezing. I use pink insulation board that fits the windows tightly and the pull down blinds help hold it in place. I had to rework the duct work on my unit to even out the heat. It had too much heat in the front and not enough in the back. I ran a new duct behind the kitchen cabinets to the rear living room and shut off some of the ducting to the front bedroom. Be careful when shutting off ducts that you don't back too much heat into the plenum. If you want to live where it is really cold you might have to close or skirt the trailer. Let the water drip when it is really cold and have a hair dryer and portable heater handy just in case the water lines freeze. Had a time or two where the water wouldn't run until noon. The coldest we camped was about 5 above. We have seen people pack up and head further south in Florida if they forecast is for 30 degrees. That is why they have wheels.
