Pete15
May 13, 2015Explorer
Heartland Error
I recently purchased a 2014 Heartland Torque SS, model #261. The VIN placard indicated the trailer was equipped with ST235/80R16E tires and appropriate axel to fit my desired needs. However, when re...
kaydeejay wrote:Pete15 wrote:If the wheels and tires can support the weight on them (trailer weight MINUS the pin weight) when loaded to GVWR, then you do not have a case!
I am just trying to make the most of a bad situation which is why I am wondering about changing the axel and tires.
At worst the Manufacturer made an error with the label.
Now, if the wheels and tires on the unit CANNOT support the actual weight on them, then you should go after them with both barrels blazing!
Good luck
