I recently purchased a 2014 Heartland Torque SS, model #261. The VIN placard indicated the trailer was equipped with ST235/80R16E tires and appropriate axel to fit my desired needs. However, when re...
To your original question, you can put bigger / higher capacity tires and axles under the trailer. But, that will not necessarily increase the load carrying capacity of your trailer, which is also a function of frame strength.
I've got to wonder if they got the axles and tires wrong, did they also overstate what the frame can handle? Because if you the consumer changes the axles and tires it can give them cause to deny all warranty claims. Keep working on having the factory make any changes.
