ricatic wrote:
justme wrote:
Gawd the Heartland owners can get excited and boarder on insane if anyone does not bow to them. Heartland is not a bad company-- they are no better or worse than other reputable manufacturers. Again the Landmark is an optioned up Big Horn and are simply a mid-level trailer. I provided some specifics as to why I choose a Redwood and not a Landmark and now I get attacked for not being factual. I find that offensive and humorous at the same time. BTY I can find as many people who like Redwood, Montana, Cedar Creek, DRV and etc as I can who like Heartland. And I can find folks who don't like them as well. So what does it all mean-- don't be fooled and do your own investigation and really look with a critical eye at the RV shows or dealers.
...maybe it is the tone of your postings...you were called out because your commentary regarding empirically verifiable specifications were so far from fact.
Your opinion of the level of manufacturing that Heartland holds is an "opinion" and is yours to hold. The other stuff you quoted as facts need documentation provided by you if you wish for them to stand...
I hope you noticed that Don gave you the benefit of the doubt...
Regards
Also has to do with your lack of real facts...in your original post you stated Heartland uses "particle board"...SOO NOT TRUE!
Heartland uses Weyerhauser OSB (oriented strand board) which is used in many stick built homes in place of plywood, as it is extremely water resistent. If you did some real research you would know there is a major difference between the two!!
