JKrussow wrote:
HappyKayakers wrote:
jesse.m.jm wrote:
JKrussow wrote:
Just went through night #1 in Alabama with temps in low teens and tonight will be even lower. Being that I full-time I made a heated water hose and have extra propane on hand. At 13 above I had a moment this morning of no water but that only lasted about 15 minutes. Tonight I think I'll let the water trickle when I go to bed (gray tank open of coarse) and see if that helps.
That may not be the best idea, as leaving a trickle of water with your grey valve open could lead to the trickle of water freezing in your dump line, and could cause a blockage there...
I did that one winter in Amarillo. Temps were in the teens for several days. When I finally checked the sewer hose, it was a 30 ft popsicle and several fittings were cracked. :(
That is one of my fears but that's what the park advised. I think I'm going back to removing the hose for the night and use tank water for my morning shower/coffee.
So, just because I am curious, when you made your heated hose, you took heat tape, wrapped the hose with it, then put foam insulation around that, and then taped up the insulation? If so, did you happen to leave a little extra heat tape out each end? I found that if you leave a little extra out each end, you can wrap a little of it around the faucet connections on each end and that helps too. Not sure we get as cold of temps as you are seeing now, but we had a spell of 20 degree weather for a couple weeks last month and we never lost our water supply at all. Also make sure the pipe coming out of the ground is wrapped and insulated if possible too.
