enblethen wrote:
Remove the cover from the 120 volt breakers. Make sure that someone has not installed a bonding screw in the neutral buss. There should be no connection between neutral and ground in the rig. I would al most bet a nickel on this!
Next: Pull the connector out of the side of the rig. Make sure they are clear of each other. This is somewhat of a problem with this type of connectors. The strain on the wire pulls them out.
Next locate transfer switch, normally behind the 120 volt AC breakers. make sure there is nothing shorted together.
I will get after it tomorrow. :C
