JRscooby
Nov 08, 2019Explorer II
Texas? Can you barrow some pipes? Lay down plywood, lay pipes across, then block or stack of blocks under the low part of frame. Crank up legs to put weight on blocks, and pull. Remember the pictures of the slaves building the pyramids? Any force to slide the legs has a lot of leverage to bend things. Better to hold low...
About Fifth Wheel Group
