- cpaulsenExplorer IIOn my 09 Wildcat....it is in the basement right next to the water filter.
- cKarlGoExplorer
Dick_B wrote:
Turn it on and follow the sound?
x2 - John_BridgeExplorerMine is to the rear of the basement, not anywhere near the fresh water tank. It's in with the converter, water heater, furnace. There is a sliding panel in the rear of the basement.
- therinkExplorerWherever your water hose hooks to the city water connection on outside, it will be near that. Likely behind a panel in basement or false panel inside. As stated, turn it on, you'll hear it.
Steve - AZ_T_TExplorer
Dick_B wrote:
That's what I would do.
Turn it on and follow the sound? - hmknightncExplorerIt's behind your water works panel. Likely have to remove a back panel in front storage bay to get to it
- danorenExplorerTake a look at the manual or call Forest River service
- brireneExplorerDuplicate post.
- brireneExplorerCould be under a cabinet or behind a panel. If you can't hear it at all, that would be a first.
- wkswensonExplorerAny where is possible.... but if that 5er has a docking station where all the wet stuff is mounted, should be a short distance from that location. Otherwise within about 3-4' of your fresh water tank. Sorry not much more help than that.
If it is working, then as said, turn the pump on, run the water and follow the sound.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
