Durb
Jul 27, 2018Explorer
If were me, I would start to demo that lock from the outside. It will need to be replaced anyhow.
There are 4 screws holding the inner and outer plates together. They are 2 1/4" apart. The top screws are 5/8" from the top of the outer flange. The lower screw on the door hinge side is 2 1/2" down from the top screw. The lower screw on the jamb side is 3" down from the top screw.
I would start with small drill bits and get progressively larger until you hog out the screw mounting posts. I took these measurements from a 2008 Carriage product so I assume they will be close. Good luck, I hope your drill isn't in the trailer!
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 16, 2026
