ChadHubbard's avatar
ChadHubbard
Help finding 12 volt fuse for refrigerator
I have a 2003 Fleetwood Pride 32' fifth wheel. The cooling unit failed on the refrigerator. My wife and I replace the cooling unit today (that was a good time!).
When I removed the 12 volt positive wire from the circuit board I allowed it to touch a piece of metal that was grounded. Blew a fuse. We re-installed the refrigerator and wired everything up. No 12 volts I can not located any 12 volt fuses.
The unit has a 55 amp inverter which is working. I have tested for voltage coming out of it and to the two distribution boards. The main 12 volt wire goes 'up' somewhere and comes back as 2 smaller cables feeding the distribution boards. There are fuses and breakers. I can follow the wires from the refrigerator almost all the way to the inverter, but not quite.
We have looked thoroughly for a 12 volt panel in addition to the distribution panel. No luck.
Anyone have any insights when the 12 volt feed for the refrigerator is connected to power?
thanks much!
Chad
