Dr_Quick
Nov 23, 2016Explorer II
Hydraulic hoses run under extream pressure, so I doubt that a do it yourself fix will work. Hydraulic lines break and need repair on construction equipment. So you should be able to find a place near you that can make up new lines for you. I would take in existing lines and the replacemant pump to repair place and they should be able to help you.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
