Mountain_Mama
Jul 31, 2018Explorer
I haven’t looked at your particular floor plan but can you get to the fridge and toilet with the slides closed? Important to us when stopping to eat lunch on the road or need a bathroom break in the middle of no where!
Video the prepurchase walk through because you won’t remember every thing they tell you about how things work. Also if you find a problem(s) that need fixing get it done before you sign final paperwork. Online there are predelivery check lists to make sure you don’t forget to check something. Tell them you want some water in fresh water tank, propane, power hooked up so you can check all appliances (cooktop, furnace, a/c, toilet, faucets, water pump ,everything ) before signing off on it. Also do research on "China Bomb" tires. Either plan on paying for an upgrade on good tires or plan on replacing them yourself ASAP.
Get them to show you how to manually retract your slides in case you need to at so,e point.
About Fifth Wheel Group
