BurbMan
Jul 19, 2018Explorer III
ol Bombero-JC wrote:FLY 4 FUN wrote:
After reading so many horror stories on here from folks that have done a DIY 50A install and even paid to have it done might I suggest:
If you do it yourself be 100% knowledgeable on how it works, to avoid frying your rv with 220volts.
If you hire a professional....be sure they know exactly how a 50A rv outlet works as too many of them end up frying rigs with 220V
Daryll
Double ditto!
*BEST* answer to the OP's question - (no disrespect, OP but maybe you should hire an electrician).
And.....
ALL the previous posts should have had the above as a "disclaimer".:R
NO NO NO
Read Gordon Three's answer above. The 50a outlet DOES use 220v. The 30a does NOT. The "horror stories" come from the 30a RV outlet being wired for 220v like a residential dryer out;let, instead of the proper 120v.
The 50a RV service IS 220v and uses the same outlet as your residential stove.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
