Me_Again
Jul 19, 2018Explorer III
Whoever said they had #10 wire with a dual 50 amp breaker, you need to replace it with the dual 30 amp breaker. You risk lighting up the #10 wire with 50 amps. Everything will work the same, except if you draw more than 30 amps you trip the breaker vs burning up #10 wire and maybe your home. Do it, switch to the lower rated dual breaker asp.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
