dpgllg
Aug 02, 2016Explorer
RamWilderness wrote:
This Eyebolt works for me. I use my awning rod to snag it. If you have an electric awning you could make up something similar. There is no weight against the pin or bolt so it can be installed with the trailer weight on it. Use a nylock nut on the end and don't over tighten, the leg will easily crush. Hope this helps.
OP Here
This looks like it might work. I have the snap pins will just have to pull the leg up fast enough to keep pin from snapping close
Thanks for a possible simple and inexpensive way to help the situation!
Dave
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 18, 2026
