On_Gorton_Pond's avatar
Aug 07, 2015
Help...Reese Sidewinder / Revolution or Pullrite Superglide
Hello,
I'm looking into replacing my manual sliding hitch with either the Reese Sidewinder/Revolution pinbox or the Pullrite Superglide hitch and would like to hear from those of you that are using them and the pro/cons of each.
Before you ask, yes I did crunch my cab with the fifth wheel and although my manual slider hitch has been great I did not even see it coming when I did this, so I'd like to prevent it from happening again.
I was pretty close to pulling the trigger on the Superglide, but the one thing that concerns me is the 10 degree limitation on hitching and unhitching. My RV is 40ft and there are times where I can see needing to hitch or unhitch at a sharper angle. The sidewinder appears to be up to 90 degrees if needed.
Thanks in advance for your input.
