azrving
Aug 16, 2016Explorer
BAILEY02 wrote:rjxj wrote:
Wet bolts may help as they lube the suspension pivot points with a grease gun
What are wet bolts?
I found your answer! Thank you, I have forwarded the info to the boss.
One example, not necessarily the model you need
I used a kit like this on my tandem axle FW.
You could go under it and oil the heck out of the hanger pivots and pull it some and re oil and let it work in and listen to it to see if it helps quiet it down before spending any money. Use it to help diagnose. On the other hand just my opinion I wouldn't run anything without wet bolts so I put them in at the start. You are trying to find a problem so......
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
