57_Panhead
Jan 25, 2014Explorer
BTPO1 wrote:
I agree with the others on checking the ground connections.
You say that there is voltage at the plug, but is that at the brake terminal or at the 12 volt battery charge terminal? There should be only be voltage at the brake terminal when the brake pedal is pushed. JMO
I have confirmed that when the controller is activated that there is power to the trailer brake terminal on the plug.
Steve
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
