btd35
Jan 25, 2014Explorer
Listen to Chris. Pull the emergency brake pin with it disconnected from the truck. If they work then check your wiring at the plug on the trailer, or get yourself a 12 volt needle light tester and check for voltage on the trailer lighting. I've had times the truck outlet has power, but the trailer plug did not make a good connection with it.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
