Me_Again
Jan 26, 2014Explorer III
btd35 wrote:
Listen to Chris. Pull the emergency brake pin with it disconnected from the truck. If they work then check your wiring at the plug on the trailer, or get yourself a 12 volt needle light tester and check for voltage on the trailer lighting. I've had times the truck outlet has power, but the trailer plug did not make a good connection with it.
This is a very simple test that cuts the location of the problem in half with only a couple minutes of your time required!
Chris
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
