- spud1957ExplorerFirst off, welcome to the forum. Lots of great info here.
Perhaps a little more info will help. If it's the television you are referring to, you may receive better responses in the "TECH ISSUES" forum.
Perhaps the moderator will move this if that is the case.
S - Onespeed405ExplorerMine sits atop of the fireplace, with screws securing the television base from underneath.
If you want to remove the television, you must first remove the fireplace to get at the screws. - Me_AgainExplorer IIIMaybe a screw hanging down on the bottom of the bracket in the center. Loosen and tip the bottom of the TV away from the wall and lift off. Chris
- Toolguy5Explorer III
dobbe6288 wrote:
TV has safety barmounted across under the tv can see the both ends--how can it be released?
It you are talking about a television, mine has a chain that goes across to release. - Coach-manExplorerWhen you type TV what you are saying is tow vehicle! Read your question again using tow vehicle, it makes no sense! If you are in fact talking about a Television, then on this forum at least spell it out.
- Me_AgainExplorer IIISeems like he is talking about getting a TV removed from a wall!!!!! There are many different brackets available that all work differently.
Chris - sayoungExplorerDon't have a clue to what you are asking about.Have a photo?
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 24, 2025
