My wife and I are planning to purchase our frist 5th wheel.We have decided on a Montana 3750FL. If anyone owns one please tell me what you use for a TV. Do I need a DRW or can I get a SRW drive Pick U...
16,270 * .20= 3,254 lbs of Max pin weight. Add 250 lbs for a 20 k hitch and you have 3,500 ish lbs sitting on the truck before you get in the truck, that is, if you are fully loaded. You need 4,500-5k lbs of payload for your truck and this trailer...you are squarely in Dually range. I would even consider a 350/3500 series DRW truck MINIMUM.
