CurtisFamily's avatar
CurtisFamily
Help with Companion Pivot Arm position Please
Installing our new B & W Companion today. In the instructions I get 9 options for where to mount the Pivot arm for different vertical and horizontal positions. I can figure out the vertical placement so that we end up with a level trailer when towing and adequate clearance above the bed. However, do I want my Kingpin 3" behind the post, 5" behind the post, or 7" behind the post. We have an 8 foot bed, so I'm not concerned about clearing the cab, but do I want the kingpin closer to the cab or closer to the tailgate? What is the difference? Ride? Thanks in advance for the opinions.
  • The king pin should be over the rear axle or slightly forward.
    Truck 'carries' the trailer pin weight. That weight is carried by rear axle/suspension/tires (very little weight will be transferred to front axle)
    Farther that weight is behind rear axle the more unloaded front axle will be.
  • My B&W center line (pivot) is about 1" behind the axle center line and in the lowest set of holes.
    I am still slightly nose high but it tows just fine.
    My truck has a service body so mine is kind of a unique situation.
    We have towed the fifth many mils so I don't think any changes are required.
