We just purchased a Lifestyle LS36FW. It has a @30ft slide out. If I am running it in or out and I stop It takes about 15 minutes before I can resume. Anyone know what's up with this?
Your answer is on the carriage/lifestyle forum. The wire used for the slide motor may be loose or under sized, not sure which but if you go on that forum you will get the problem solved by people with the exact same experience.
