Me Again wrote:
dmaxing wrote:
Any one have a manual for the old Hijaker 16k hitch that had has the adjustment bolt on the back of the hitch head need the info on how much tighten the bolt and also the tork amount on all the bolts. Thanks
That adjustment bolt is a bit of trial and error. You want it as snugs as you can go without creating a situation where the release handle is hard to pull. You should be able to use a standard torque chart for the bolt size and grade. If I recall they are 5/8" bolts and should be able to handle 90 ft lbs without any problem.
I love mine! I got it in 1997 and it has served well in two trucks and with two trailers. I repainted it a few years ago and Hijacker sent me new labels. Since then they have sold the company and are no longer based in Victoria, BC.
Chris
Thanks, I have had mine now for 11 years, now on my second truck beautiful hitch.
