agesilaus
May 10, 2015Explorer III
You should be able to adjust the hitch up/down and the same with the pin box. Unless they are already adjusted fully in the needed direction. The pin should be a little below the hitch skid plate anyway when you hitch. Best to have a helper when working on the pin box as they are heavy.
Otherwise you could get a couple of bottle jacks and jack up the front of the 5ver enough to complete hitching be sure to do a good job of chocking the 5ver wheels as you don't want to knock it off the bottle jacks. You should own one bottle jack anyway in case you need to work on the 5ver on the road.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
