As a Patriot owner I see absolutely no way the pin can come out of the jaws when hitched. If you back into the hitch so that the pin box presses on the top of the 5th hitch and the handle closes then it's secure. Pin the handle and that's it. Only way a B&W can not be hitched is if you don't pin the handle and it comes lose. That's not B&W's fault, that's owner error. I had an older Reese before the B&W and same thing on hitching. A look test when plugging in the 7 pin is all that's needed. Those that disagree with this don't own a B&W. Your pin has to be at the right elevation in the jaws to close the handle. It's a no brainer.
