Measure from the center of the King Pin to the rear corner of the pin box assembly, then measure the distance between the TV bed rails and divide that number by 2. You will most likely find that the Pin Box is longer the half the bed rails distance. So the only real solution is to remove some of that material on the rear of the pin box, because if you try to raise the Hitch and Lower the pin box to gain clearance you will find yourself Nose High.
I've had the same issues with a 2005 3500 Dually and current 2011 3500 Dually and three different fifthwheels.
