johndeerefarmer
Jun 12, 2018Explorer III
oldretiredafguy wrote:B.O. Plenty wrote:oldretiredafguy wrote:Let it go when I sold the hitch. It was on a Super Glide. If you really want one they don't look like they would be hard to fabricate.B.O. Plenty wrote:
Last I heard he was out of business. I had one for my old rig. Got to thinking, if I was too dumb to make sure the hitch was latched why would I latch the Butchs setup. I now have a B&W hitch, I do check it when I'm hitched but can't see how it would be a problem
B.O.
Do you still have it laying around? I would like to buy it if you do!
Mike
B.O.
I agree, except for getting the roll in cold steel correct.
Maybe someone else on the forum has one on a shelf in their garage that they forgot about.
Thanks
Mike
It would be easy to fabricate. Use a piece of sucker rod and find a piece of pipe that fits over that. Weld a piece of flat strap to a short piece of pipe and bolt them at each side of the hitch plate. You could weld a washer on one end for a cap and then drill a hole in the other end and insert a hair clip. I have been able to drill holes in some sucker rod but not others.
I have had two of his latch kits. I will make my own for my new hitch.
The idea of the latch kit is not if you forget to latch it but if it doesn't latch and LOOKS like it is latched. My Pullrite was really bad about that..
About Fifth Wheel Group
