joe_puma
Dec 04, 2015Explorer
Hitch Lock?
I just had a B&W Patriot slider installed. Not to be paranoid, but I'm thinking about how all you got to do is pull 4 pins and it could be lifted out. Two questions, first, how many people use a locki...
Learjet wrote:joe puma wrote:
I just had a B&W Patriot slider installed. Not to be paranoid, but I'm thinking about how all you got to do is pull 4 pins and it could be lifted out. Two questions, first, how many people use a locking pin similar to the bumper hitch to lock in their hitch? Second, on my hitch the head lifts off even easier, does anyone lock it t the main hitch when not towing?
Thanks.
I have the non-slider Patriot, I happen to have a cable lock that works perfect for this. I feed it through the front rails then up and around the front of the head pivot point. Everything is locked together and there is no interference with movement.
Like other have said, if you really want it they'll take it, but it will make someone think twice.
you can see it in this photo:
