Cummins12V98 wrote:
RobWNY wrote:
I don't know if my choices of lubricants are right or wrong but I use Blaster White Lithium Grease on the jaws and pivot points before each use and I have a grease zerk fitting on the underside of my B&W that gets some Red N Tacky grease once a season. On the pin I use a Lube Plate. It keeps things from getting messy because I don't have to grease the plate itself
Overkill on the pivot points and under kill on the supporting shaft with the grease ZERK.
To clarify...I only grease the support shaft zerk once a year because B&W recommends once every six months for the amount of use my hitch gets. Here in the Northeast, 6 months is all we get for camping so it is a once a year deal for me. I lube the polyurethane bushings every time because they are always dry when I check them. You're probably right about the jaws though. I just spray the lithium grease because it's already in my hand after doing the bushings.
