rhagfo wrote:
Bombfixer wrote:
Before you get that lube plate, look at your hitch. I am not familiar with the B&W, but my new Reese has a lube pad built onto the jaws to do the same thing. Using one of the white pads on a hitch with the pad on it might effect your hookup ability.
What Reese is that, "Lube plate on the Jaws", the lube plate goes between the pin box bottom surface and the top surface of the hitch saddle.
Is this what you are referring to?
Reese Lube plate
Yes that item is what I have. The hitch is a Reese 21k that I got in Sep from Camping World of Chattanooga.
