I have a 2010 Ram 3500 4x4 SRW megacab 6' 4" bed towing 2014 Keystone Alpine 3500RE 100" wide 14k lbs loaded. Have a B&W companion hitch 4" behind rear axle center. In over 10 k miles towing have not needed a slider due to rounded corners on 5ver. I have watched very carefully and has looked close but cab is still untouched. Keystone calls it an 88 degree front cap. If you get careless and exceed that 88 degrees you will pay but that is true of all 5vers if you turn too sharp it WILL hit. It is called "jacknifing". IMHO.
