plasma800's avatar
plasma800
Hitch Setup, Look good?
I setup my companion.
The arms are all the way forward and in the center holes.
I have 10 inches of clearance at the front and 9.xx at the tailgate.
I put a level on the ground outside of the door and then inside on the floor and got a .8 degree difference in slope with the 5th wheel being the greater number.
I'm trying to decide if I should lower my arms one more tick.
  • plasma800 wrote:
    Cummins12V98 wrote:
    Lower the arms by 2 inches. Be sure the STRAIGHT side of the head supports are closest to the cab.
    Good call on the B&W!
    If it's not raining, I'll go move them tomorrow. Then maybe I should go find a scale...
    That is always a good choice to know your weights!
    On LEVEL ground measure from bottom of RV frame to ground at front and rear. Weigh the trailer axles separately also.
    Agreed!! So much better than my old Reese Elite!!
    You're gonna love it!!
    Mark
  • Lower the arms by 2 inches. Be sure the STRAIGHT side of the head supports are closest to the cab.
