Cummins12V98 wrote:
mtofell1 wrote:
I leave mine hanging but do support the majority of the weight with a jack stand. The jaws of my B/W hitch bound up once after hanging for a few months and I was afraid leaving it hanging may have caused it.
Most likely did not bind up as you needed to back against the kingpin and pin the hitch handle open and gently pull away.
Yep, once I got it in the truck and was able to do that it released. I was just in a bit of a spot as I had to line it up perfectly to get it in the truck. Usually, I just back under it, lower the 5th until the hitch sits in the bed, release it, pull forward, lug it into position and latch it, then back up and hookup.
