DRM796
Mar 11, 2015Explorer II
Hitching At an Angle
Was wondering if it is OK to hitch a 5th from and angle? (not uneven ground but from the side) If so how steep of an angle is exceptable?
mileshuff wrote:ford truck guy wrote:Coach-man wrote:Only True Mosnowman wrote:
I have a Pullrite SuperGlide....you CANNOT hitch at an anle. You pretty much have to be dead on straight to hitch and unhitch. Only thing I dislike about this hitch...
X2 the ONLY draw back to the Pullrite Super Glide! I think the max angle they recommend is something like 7 degrees, which is almost straight in.
CORRECT.. It is 7 degrees...
In 7 years of using my superglide , I have never ran into an issue with unhooking . .
Pullrites owners manual states 16 degrees. At least mine does. Might vary by year. I've never had a case where I had to hitch or unhitch at extreem angles.
