rtreptow7
Jun 07, 2018Explorer II
Honda Generator "revs up" every 20-30 minutes?
Got a new rig this year. Still running our Honda Generator 2000. Mainly just run it to charge the batteries up in the coach. I have it set on eco mode and it usually just stays at a low idle. On our new camper, about every 20-30 minutes? The generator revs up for about 5-7 seconds and then settles down again. Never did this on our old camper. Is there something in the new camper that powers on every so often to cause the generator to do this? It happens even when nobody is in the camper using anything. If the generator is running and I turn the sink on to activate water pump, that doesn't cause the generator to increase rpm. Can even have some lights on and a fan with water pump on too and it doesn't cause the generator to rev up. I wonder what could be Powering on every so often to cause the increased RPMs on the generator? Air/Heat is off too. Generator doesn't rev up like that when we plug in to another camper.
