flyfishing48's avatar
flyfishing48
Hose in 5 gal bucket?
DF was telling me that today while we were breaking camp she saw another camper putting his water hose away.
He was pushing the hose back into a 5 gal bucket with a hole in the lid that was slightly larger than the hose diameter. We assume the other end of the hose was coming out of a hole in the side of the bucket near the bottom.
This concept has some attraction for me. It is neat, simple, and I think the hose would stay cleaner. But it seems to me that stuffing the hose back in will result in kinks.
Is anyone else using this method?
I am thinking it might not be all that great an idea or I would have seen someone doing this by now. We have been camping since 2005 and until this morning, haven't run across it before.
  • I think you could coil the hose properly as you stuffed it into the bucket. The main issue I see is that it would be a big waste of space for most of us. You could probably get 200' of hose in a 5 gal bucket, which is a lot more than most people carry. If you just have 50 or 100', that's a lot of wasted space.
    I just coil them like most others do, and screw the ends together. Never needed more than 2 x 25 footers.
  • rhagfo's avatar
    rhagfo
    Explorer III
    I also coil and connect ends. Clean and takes up little space.
  • A hose, like rope, has a natural lay. Try to force it by doing the hand around the elbow method will kink & destroy it in no time. If the hose is soft it will coil inside the bucket.
    Likewise the shorepower cable, especially 50amp & worse when it is cold, is a pain to coil. We use a laundry hamper for our 50amp cable. Enough comes out of the trailer end from the bottom of the hamper to reach the trailer input. The post end is pulled out as needed with the balance staying in the basket.
  • In all the years we've been at RV parks, I've never seen this. We coil our water hose up then connect the two ends, using ratcheting clamps to hold it in place before putting it in a lidded plastic tub.
