readytow wrote:
With the shower head removed, it does not do the hot and cold cycle. It stays at whatever temperature I set it at. So, I have replaced the shower head with 3 different shower heads, every shower head does the hot/cold cycle. what do I do?
The water temp stays steady and pump doesn't cycle without the shower head(s) but does when shower head(s) are screwed on.
That is due to the flow restrictor in the shower head......remove it or drill it out. In the handle. Temp should stay steady and no pump cycling without restrictor.
Still will have a slight change of temp when using the on/off button on handle due to hot/cold mixing inside handle....so when you turn the shower head back on hold it away from you for a few seconds.
