Old-Biscuit
Nov 16, 2014Explorer III
With drain plug out OPEN Water supply and stand back........let the cold inlet that comes in at bottom of tank blow the tank (junk/debris/crud) out under force.
And as others have stated....pump sucks from fresh water tank only.......it then discharges under 45# pressure (or higher) into cold water lines off of which is the inlet to tank. HOT water comes out top of tank.
SO if any debris should get carried out of WH tank you will get plugging of faucet aerators and possibly shower.
Anode Rod
No NEED to replace until 75% Gone.
Anode Rod
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
