garyp4951Explorer IIINov 16, 2014Hot water heater full of debrisWhen I was winterizing my camper I shut off the valve to the water heater, and then pulled the plug to drain it. I probably had a half cup of metal debris from the anode rod come out, and a lot more l...Show More
old_guyExplorerNov 16, 2014they make a gizmo you put on a garden hose to flush out the tanks. get one, use it.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???found debris draining water heater
