chevyman2
Nov 17, 2014Explorer
easy way to flush a water heater is to remove the drain plug (Atwood) or anode rod (Suburban) and plug in the hose to city water, let the water pour. If it is cold or in a place you want to stay dry (or simply want to conserve water). You may place a blow out plug in the city water connection, and let air pour thru the system. Either way, as long as the plug is removed from the water heater, it will clean the heater tank pretty well.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
