Old-Biscuit
Sep 24, 2018Explorer III
What Brand/Model?
If it is DSI (Direct Spark Ignition) then gas valve solenoid and Spark electrode are energized at same time.
Spark electrode fires (Click, click, click) while gas flows to burner ---spark ignites flame and then 'flame proving' signal is sensed by circuit board and holds dc on gas valve/stops it to spark electrode.
No spark....
Wrong gap ----should be 1/8"--3/16"
Bad wire connection from board to electrode...loose/dirty
Bad wire thru ceramic...replace electrode
Bad ground connection....electrode mounting screw provides ground....clean/tight
Bad circuit board....spark circuit/high voltage transformer etc
Water temp has to be down below 100*F/110*F (Brand/Model) in order for t-stat to close and call for heating. Otherwise no reason to heat.
No spark....
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
