sin_cal_hd
Sep 24, 2018Explorer
nayther wrote:
you said the burner stays on if you turn on the hot water? If that's the case then it's something in the thermostat circuit would be my guess. Need a volt meter and wiring diagram for proper diagnosis. When you hear the spark do you SEE a spark?
I run the hot for a few seconds and shut off. You can hear "something" click. No spark. But you can smell propane coming out of the pin hole. I can manually light it with a lighter. It will run for a quick second or 2. Then shuts off.
I have looked at the thermocoupler,and it looks to be in place. Nothing seems to have caused it to move. We've only used the propane side to heat 2 times now. We've always been hooked to electricity while camping.
I've been asking around and some say it could be a temp sensor or electrical board.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
