bpounds
Sep 23, 2015Nomad
For the real tight penny pinchers, with a lot of time on their hands, you can do your own study.
1. Leave the water heater on all day. Using gas or electric or both. Doesn't matter to me. Sit around all day and keep a record of how many minutes and seconds, total, that the water heater is active.
2. Turn it off after every use, and go about your normal routine, but don't wander away, because you have to count how many minutes and seconds, total, that the water heater is active. If you are the only one using water, it will be easier and you can wander away all you want.
It is simply a matter of totaling up the time and comparing.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
