Do you leave our pump ON when boondocking or do you turn it ON when you go to use water?
With pump left ON..........it would run momentarily every so often IF there was a leak in system due to drop in system pressure.
Temp/Press Relief Valve on water heater would show signs of leaking---scale etc on gas solenoid valves directly below it.
With pump only being turned ON when you use a faucet/toilet then back off water could backflow thru pump back to fresh water tank.
But when on city water fresh water tank should fill up/over fill if pump check valve was weak.
So ........how do you use your pump when boondocking ON or On/Off??
