dpam's avatar
dpam
Hot water tank temperature- pressure relief valve
The hot water tank temperature/pressure relief valve was leaking water, so I was trying to remove the valve and install a new one. I see there is some white plumbing tape around the threads and there must also be some rust. I assume the factory probably tightened the valve too much when it was installed. I tried to remove the valve with a crescent wrench and a pipe wrench and I can't budge it and in fact I broke of a piece of the spout trying to get the valve to turn. I don''t know what type of wrench will work, because there is limited space to get a wrench around the valve. Any thoughts on what might work? I sprayed some rust busting oil around the thread opening, but no luck so far.
  • Have had 2 rvs in my 9+ years fulltiming. Both pressure relief valves I've had have leaked. There are stories of fixing it by making sure air is in the tank (tried it...never worked). The best thing I have seen is attaching a hose to the prv and leading it out of the access panel to drip harmlessly on the ground. If you find a solution that works, post it here. I would be interested as mine still weeps.
  • You check to make sure this "leak" was not the very common, and easy to fix, "weeping" that occurs when the water tank loses its air gap?
    Tom
