Old-Biscuit
Sep 07, 2014Explorer III
6 gallon is doable provided you take 'NAVY' showers.......wet down/turn off---suds up/rinse.
Course you can also change out normal temp t-stat for a higher pre-set one to increase the temp of hot water so that it 'lasts' linger (using more cold to temper the water temps) Atwood even has an adjustable one available (110*F-150*F)
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
