Old-Biscuit
Sep 08, 2014Explorer III
Itching2go wrote:
Might also check to see if it's an Atwood with a model number that begins or ends with "EXT". If it is, you may be looking at one that has an effective capacity above 6 gallons. These models accomplish this by heating the water well above the standard 120 degrees, then mix in cold water through a mixing valve at the tank outlet to reduce it safe temperatures. We have this with our 10 gallon gas/electric, and it yields an effective capacity of 18 gallons.
Something to check out..
Standard Atwood heats to 140*F (Normal t-stat set point)
The XT model heats to 160*F then uses the mixing valve to regulate output temp to 130*F
Mixing valves can become clogged if water source has high mineral content.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
