rsgs
Aug 01, 2018Explorer
Agree with MFL. I am restoring a Forest River Wildcat and it has a Lippert hydraulic pump to extend and retract the slide. The slide has multiple adjustments underneath for up/down and left right. As was stated, be careful when you make an adjustment because you also changed something somewhere else. One thing I made sure was to mark all the original settings either with a scribe on the metal itself or using a silver sharpie before I started tweaking. This allows you to go back to the original setting if the adjustment was too much or didn't work. As Also stated, there are a bunch of You Tube videos. Sort through them because some are not recommended or won't solve your problem. Good luck - it can be done. ps: when I asked for a quote from the local dealer on adjusting it, they told me it could be anywhere from $200 to $5000 or more, depending on what is wrong, what has to be fixed, etc.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
